Configure PIM on a Port
Configure PIM for each interface to enable the interface to perform multicasting operations.
  • You must enable PIM globally before you configure it on an interface.
  • The interface uses a valid IP address.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Create a PIM interface on a port:
    ip pim enable
    This command creates an active interface, by default.
  3. Configure the interval for join and prune messages:
    ip pim join-prune-interval <1–18724>
  4. Configure the time between hello messages:
    ip pim hello-interval <0–18724>
Configure the interval for join and prune messages and the time between hello messages:
Switch(config-if)#ip pim join-prune-interval 60
Switch(config-if)#ip pim hello-interval 30
